メインコンテンツにスキップ
How To Fix A Loose Bicycle Pedal And Check For Damage
Thomas Paulsen
Thomas Paulsen とその他 11 人の作成者
最終更新日: May 26, 2020
10 - 15 分
中レベル
A loose pedal can be dangerous for bicycle riders. This guide will show you how to check for damage and tighten the pedal on your bike.
必要な工具と部品
ツール
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. How To Fix A Loose Bicycle Pedal And Check For Damage, How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 1、 1の画像 1
    • Flip the entire bicycle upside down, balancing the weight on the seat and handle bars.
    • This will keep the bicycle stable while you work on it.
  2. How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 2、 3の画像 1 How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 2、 3の画像 2 How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 2、 3の画像 3
    • You will need an Allen Wrench or a Smart Wrench for this repair.
    • If you are using an Allen Wrench, insert the head of the wrench into socket located on the pedal arm.
    • If you are using a Smart Wrench, place the jaws on the nut located between the pedal and pedal arm.
    • Loosen the pedals by turning the right pedal counterclockwise and the left pedal clockwise.
    • Remove the pedal from the socket.
  3. How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 3、 2の画像 1 How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 3、 2の画像 2
    • Check the socket and bolt for rust and worn threads.
    • If you notice damages like rust or worn threads, you will need to refer to a separate repair guide specific to the type of damage.
    • If you do not see any damage, continue to Step 4.
  4. How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 4、 3の画像 1 How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 4、 3の画像 2 How To Fix A Loose Bicycle Pedal And Check For Damage: 手順 4、 3の画像 3
    • Place the pedal back in the socket and tighten it until it is secure.
    • To tighten the pedals, turn the right pedal clockwise and the left pedal counterclockwise.
    • Once you feel resistance, turn the pedal about 1/8 of a rotation further to properly tighten it.
    • DO NOT use excessive force when you are tightening the pedal. This can lead to difficulty removing the pedal in the future.
終わりに
If both pedals need tightening follow the steps again, remembering to turn the opposite directions for tightening and loosening.
9 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Thomas Paulsen
メンバー登録日: 02/23/15
218 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-1, Green Winter 2015 Cal Poly, Team 12-1, Green Winter 2015人のメンバー
CPSU-GREEN-W15S12G1
6 メンバー
8のガイドは作成済み
5 件のコメント
Yes, I agree, it's very nice way to fix pedals.
Praska - 返信
Would you be able to tell me how to fix a locked up bike
Hughes Zass - 返信
Wenn das Rad auf dem Kopf steht, ist das linke Pedal rechts und umgekehrt.
Klaus Giezek - 返信
My crank arm constantly comes loose, although I tightened it. I go to the bike repair store near my house, and they say that the bearing of the bottom bracket is worn. To fix this, I need to replace it with a new one, grease the new component, and tighten the bicycle crank.
Bruno John - 返信
Some reasons that crank arm keeps coming loose can happen, such as: the bolts are loose and damaged; incorrect installation; the bearing is damaged; the spindle is wiped out; An unfitting bottom bracket,...
Bruno John - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 40
過去 30 日: 128
今までの合計 67,516
