メインコンテンツにスキップ
Hollowtech Bottom Bracket Replacement
Agustin Sernas
Agustin Sernas とその他 人の作成者
最終更新日: December 27, 2023
30分 - 1時間
中レベル
With the many cranksets and bottom bracket types in the market, this guide specifically focuses on replacing a vision track crankset and similar Hollowtech II crankset. Since the vision track crankset does not have a square-tapered bottom bracket, different tools are required to remove and install the crankset. As the crankset is an important part of a bicycle's drivetrain, maintaining and keeping it in good shape is important. Before starting the guide, note that working on a bicycle is not very difficult but it can be messy.
  1. Hollowtech Bottom Bracket Replacement, Bottom Bracket: 手順 1、 1の画像 1
    • Secure the bicycle using a bicycle repair stand or wall.
  2. Hollowtech Bottom Bracket Replacement: 手順 2、 2の画像 1 Hollowtech Bottom Bracket Replacement: 手順 2、 2の画像 2
    • Use pliers to remove the spring clip from the chain's master link clip.
    • Remove the master link plate, plate and pin assembly, and finally the chain.
  3. Hollowtech Bottom Bracket Replacement: 手順 3、 3の画像 1 Hollowtech Bottom Bracket Replacement: 手順 3、 3の画像 2 Hollowtech Bottom Bracket Replacement: 手順 3、 3の画像 3
    • Use a 10mm Allen key socket and ratchet to loosen the left crank arm by twisting counter clockwise.
    • Remove the left crank arm.
    • Remove the spacer(s) and washer.
  4. Hollowtech Bottom Bracket Replacement: 手順 4、 3の画像 1 Hollowtech Bottom Bracket Replacement: 手順 4、 3の画像 2 Hollowtech Bottom Bracket Replacement: 手順 4、 3の画像 3
    • Either push or pull the crank arm fully out exposing the left bottom bracket.
  5. Hollowtech Bottom Bracket Replacement: 手順 5、 2の画像 1 Hollowtech Bottom Bracket Replacement: 手順 5、 2の画像 2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the left bottom bracket by twisting counter clockwise.
    • Remove the bottom bracket.
  6. Hollowtech Bottom Bracket Replacement: 手順 6、 2の画像 1 Hollowtech Bottom Bracket Replacement: 手順 6、 2の画像 2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the right bottom bracket by twisting counter clockwise.
  7. Hollowtech Bottom Bracket Replacement: 手順 7、 3の画像 1 Hollowtech Bottom Bracket Replacement: 手順 7、 3の画像 2 Hollowtech Bottom Bracket Replacement: 手順 7、 3の画像 3
    • Carefully pull out the bottom bracket shell.
終わりに
Congratulations, you have completed the guide. To reassemble the crankset, follow these instructions in reverse order. Make sure to grease the threads, bottom bracket shell, and crankset accordingly. In addition, torque down the crank arm (38-41Nm) and bottom bracket (40-50Nm) to the manufacturer's recommended specification.
作成者
1人の作成者と共同作成されました。
Agustin Sernas
メンバー登録日: 10/23/23
145 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 CSU Los Angeles, Team 13-3, Ribeiro Fall 2023人のメンバー
CSULA-RIBEIRO-F23S13G3
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 27
今までの合計 275
