メインコンテンツにスキップ
Heyday Active Noise-Canceling Wireless Headphones 0398 Ear-pad Cushion Replacement
Christopher Puperi
Christopher Puperi とその他 3 人の作成者
最終更新日: February 25, 2025
5分
簡単
作成中の学生
The earpads play a crucial part in the active noise cancelling experience. Without them sound would be distorted. If yours are old or need to be replaced this is the guide for you.
必要な工具と部品
ツール
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Ear-pad Cushion Replacement, Ear-pad Cushion: 手順 1、 2の画像 1 Heyday Active Noise-Canceling Wireless Headphones 0398 Ear-pad Cushion Replacement, Ear-pad Cushion: 手順 1、 2の画像 2
    • Position the headphones so that you can see the opening for the cushion. It should be along the outer edge where the cushion meets the plastic.
    • Take your IFixIt opening tool and place it between the cushion and the plastic to help you separate them.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Ear-pad Cushion Replacement: 手順 2、 1の画像 1
    • Be aware that the plastic tabs securing the cushion in place are susceptible to breaking. Use caution when using IFitIt tool when separating the cushion because damaging these tabs will result in difficulty reattaching the cushion.
終わりに
作成者
3人の作成者と共同で作成されました。
Christopher Puperi
メンバー登録日: 09/13/23
493 ポイント
5のガイドは作成済み
チーム
Austin Community College, Team 8-3, Watkins Fall 2023 Austin Community College, Team 8-3, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S8G3
4 メンバー
10のガイドは作成済み
2 件のコメント
Hello! Do you know which pad can be installed for these heydays? I'm struggling to find information on a suitable replacement. Thank you!
adahmobile247 - 返信
Do you have any suggestions on the exact link to the replacement?
adahmobile247 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 308
