HP Stream x360 11-p015wm Speaker Replacement
見積もりなし
中レベル
詳細が不足
はじめに
手順 1 に進むIf you're looking to fix the speaker on your HP Stream 11 x360-p015wm laptop, then boy are you in the right place. This guide will take you step-by-step through how to get right to your speaker and take it out! Then, follow the steps in reverse order to put it back together!
必要な工具と部品
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Locate your speaker on the left and right ends of the front rear side of your laptop.
もう少しです!
終わりに
