HP Stream x360 11-p015wm Motherboard Replacement
はじめに
手順 1 に進むThis guide will walk you through the steps of replacing the motherboard in an HP Stream x360 11-p015wm. The motherboard is an important part of the computer hardware and contains multiple main components. Follow along, step-by-step to safely remove your motherboard and then follow the instruction in reverse to reassemble your laptop! Be sure to back-up your files before undergoing this repair.
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
