HP Stream 13-c110nr Heat Sink Replacement
はじめに
手順 1 に進むThe Heat Sink removal guide will assist the user in removal and installation within the HP Stream 13-c110nr.
必要な工具と部品
ツール
もっと見る
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
Place two (2) screws on magnetic mat for reassembly.
