メインコンテンツにスキップ
HP Pavilion 17-f127ds Speakers Replacement
Stephen Brown
Stephen Brown とその他 4 人の作成者
最終更新日: December 28, 2020
10分
中レベル
A speaker is a device that converts an electrical audio signal into sound. If your HP Pavilion 17-f127ds laptop is not producing clear audio, intermittent, or no sound, use this guide to replace the speakers. This guide provides a walk-through of the steps needed to remove the malfunctioning speakers and replace them with new speakers.
There is no specific training required before executing the guide. To avoid causing any damages, be sure to turn off your laptop before beginning this guide. Make sure you have all of the necessary tools and be careful when going through each step.
必要な工具と部品
ツール
もっと見る
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: 手順 1、 3の画像 1 HP Pavilion 17-f127ds Speakers Replacement, Battery: 手順 1、 3の画像 2 HP Pavilion 17-f127ds Speakers Replacement, Battery: 手順 1、 3の画像 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 手順 2、 2の画像 1 HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 手順 2、 2の画像 2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: 手順 3、 3の画像 1 HP Pavilion 17-f127ds Speakers Replacement: 手順 3、 3の画像 2 HP Pavilion 17-f127ds Speakers Replacement: 手順 3、 3の画像 3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: 手順 4、 2の画像 1 HP Pavilion 17-f127ds Speakers Replacement, Speakers: 手順 4、 2の画像 2
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: 手順 5、 2の画像 1 HP Pavilion 17-f127ds Speakers Replacement: 手順 5、 2の画像 2
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
終わりに
作成者
4人の作成者と共同で作成されました。
Stephen Brown
メンバー登録日: 10/18/17
201 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017人のメンバー
UWT-LINER-F17S3G1
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 412
