メインコンテンツにスキップ
HP Pavilion 15-ba003ds Cooling Fan Replacement
Krushnam Badami
Krushnam Badami とその他 2 人の作成者
最終更新日: June 19, 2020
15 - 25 分
中レベル
作成中の学生
ツールが不適切
This guide will provide you with the steps you will need to follow in order to replace the cooling fan in your HP Pavilion 15-ba003ds.
This guide will be useful if you find that your laptop struggles to adequately cool your laptop.
必要な工具と部品
ツール
もっと見る
  1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: 手順 1、 2の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: 手順 1、 2の画像 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Disc Drive: 手順 2、 1の画像 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 3、 2の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 3、 2の画像 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 4、 2の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 4、 2の画像 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 手順 5、 3の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 手順 5、 3の画像 2 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 手順 5、 3の画像 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: 手順 6、 2の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: 手順 6、 2の画像 2
    • Remove three black 6mm Phillips #00 screws.
  7. HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 7、 3の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 7、 3の画像 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 7、 3の画像 3
    • Unplug the white connector using your fingers or a spudger.
  8. HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 8、 3の画像 1 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 8、 3の画像 2 HP Pavilion 15-ba003ds Cooling Fan Replacement: 手順 8、 3の画像 3
    • Pull out the fan by hand.
終わりに
作成者
2人の作成者と共同で作成されました。
Krushnam Badami
メンバー登録日: 01/14/20
342 ポイント
3のガイドは作成済み
チーム
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020人のメンバー
YORK-WOODHOUSE-W20S1G9
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 20
今までの合計 338
