メインコンテンツにスキップ
HP Pavilion 15-au123cl CMOS Battery Replacement
Mohammad Gardezi
Mohammad Gardezi とその他 人の作成者
最終更新日: December 28, 2017
15 - 20 分
中レベル
If you are noticing the settings are wrong on the BIOS, you will want to follow this guide to reset the BIOS settings. The CMOS battery holds BIOS settings so booting up the computer after removing the battery should fix all BIOS issues.
必要な工具と部品
ツール
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
もっと見る
  1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 2、 2の画像 1 HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 2、 2の画像 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 3、 2の画像 1 HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 3、 2の画像 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 4、 2の画像 1 HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 4、 2の画像 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 5、 3の画像 1 HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 5、 3の画像 2 HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 5、 3の画像 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: 手順 6、 2の画像 1 HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: 手順 6、 2の画像 2
    • The CMOS battery is located toward the middle left area of the motherboard.
    • Using the spudger, lift the CMOS battery out of its plastic casing.
  7. HP Pavilion 15-au123cl CMOS Battery Replacement: 手順 7、 1の画像 1
    • Fully remove the CMOS battery from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Mohammad Gardezi
メンバー登録日: 10/17/17
1,420 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S13G3
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 57
過去 30 日: 210
今までの合計 25,982
