メインコンテンツにスキップ
HP Pavilion 11 x360 Motherboard Replacement
Emily
Emily とその他 5 人の作成者
最終更新日: December 25, 2023
20 - 30 分
中レベル
空欄の手順
Make sure the device is powered off and is not attached to any electronics.
必要な工具と部品
ツール
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
もっと見る
  1. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: 手順 1、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: 手順 1、 2の画像 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: 手順 2、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: 手順 2、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: 手順 2、 3の画像 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: 手順 3、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: 手順 3、 2の画像 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Motherboard Replacement, Battery: 手順 4、 1の画像 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Motherboard Replacement: 手順 5、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 5、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement: 手順 5、 3の画像 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Motherboard Replacement: 手順 6、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Motherboard Replacement: 手順 7、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: 手順 8、 1の画像 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: 手順 9、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: 手順 9、 2の画像 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: 手順 10、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: 手順 10、 2の画像 2
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Motherboard Replacement: 手順 12、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 12、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement: 手順 12、 3の画像 3
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Motherboard Replacement: 手順 13、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 13、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement: 手順 13、 3の画像 3
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: 手順 14、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: 手順 14、 2の画像 2
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: 手順 15、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: 手順 15、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: 手順 15、 3の画像 3
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: 手順 16、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: 手順 16、 2の画像 2
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: 手順 17、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: 手順 17、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: 手順 17、 3の画像 3
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: 手順 18、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: 手順 18、 2の画像 2
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: 手順 19、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: 手順 19、 2の画像 2
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: 手順 20、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: 手順 20、 2の画像 2
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: 手順 21、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: 手順 21、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: 手順 21、 3の画像 3
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Motherboard Replacement: 手順 22、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 22、 2の画像 2
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Motherboard Replacement: 手順 23、 3の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 23、 3の画像 2 HP Pavilion 11 x360 Motherboard Replacement: 手順 23、 3の画像 3
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Motherboard Replacement: 手順 24、 1の画像 1
    • Remove the RAM.
  25. HP Pavilion 11 x360 Motherboard Replacement: 手順 25、 2の画像 1 HP Pavilion 11 x360 Motherboard Replacement: 手順 25、 2の画像 2
    • Lift up the heat sink to remove it from the motherboard.
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Emily
メンバー登録日: 01/22/15
487 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G9
4 メンバー
12のガイドは作成済み
コメント 1 件
La tarjeta madre soportara un intel core i5?
Rodolfo Giron - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 50
今までの合計 10,827
