メインコンテンツにスキップ
HP OfficeJet 4650 Touchscreen Replacement
Stephanie Carpintero
Stephanie Carpintero とその他 4 人の作成者
最終更新日: May 2, 2023
7分
中レベル
The touchscreen is what you use to interact with the printer. If the touchscreen is malfunctioning, the HP OfficeJet 4650's interactive functions will not work. This guide will show you how to replace the touchscreen.
必要な工具と部品
  1. HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 手順 1、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 手順 1、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement, Touchscreen: 手順 1、 3の画像 3
    • Open the cartridge access door by using putting one hand on the grooves of each side and pulling up.
  2. HP OfficeJet 4650 Touchscreen Replacement: 手順 2、 2の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 2、 2の画像 2
    • Using the 2.0mm screwdriver, remove the 14mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
  3. HP OfficeJet 4650 Touchscreen Replacement: 手順 3、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 3、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement: 手順 3、 3の画像 3
    • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
    • Push the panel upward to remove it from the printer.
    • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
  4. HP OfficeJet 4650 Touchscreen Replacement: 手順 4、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 4、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement: 手順 4、 3の画像 3
    • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
  5. HP OfficeJet 4650 Touchscreen Replacement: 手順 5、 2の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 5、 2の画像 2
    • Remove the other connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
  6. HP OfficeJet 4650 Touchscreen Replacement: 手順 6、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 6、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement: 手順 6、 3の画像 3
    • Unclip the yellow connector by lifting up the grey piece with your finger.
    • The yellow connector will pop right up when the grey piece is unclipped.
  7. HP OfficeJet 4650 Touchscreen Replacement: 手順 7、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 7、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement: 手順 7、 3の画像 3
  8. HP OfficeJet 4650 Touchscreen Replacement: 手順 8、 2の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 8、 2の画像 2
    • Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the screen to the printer body by turning the screws counterclockwise.
    • Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the green circuit board to the screen by turning the screws counterclockwise.
  9. HP OfficeJet 4650 Touchscreen Replacement: 手順 9、 3の画像 1 HP OfficeJet 4650 Touchscreen Replacement: 手順 9、 3の画像 2 HP OfficeJet 4650 Touchscreen Replacement: 手順 9、 3の画像 3
    • Remove the circuit board by lifting it off the screen in order to get the screen on its own.
    • Pull the screen off the front panel cover.
    • The clear plastics pieces will easily fall off when the screen is lifted off. Do not lose them.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
メンバー登録日: 01/24/18
994 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S19G6
3 メンバー
10のガイドは作成済み
2 件のコメント
Where do I buy the replacement screen
Aadil Hussain - 返信
Where can you buy a replacement screen
William Joseph Adduci - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 17
過去 30 日: 54
今までの合計 2,838
