HP Notebook 15-ay011nr Battery Replacement
はじめに
手順 1 に進むThis guide will show you how to replace the battery in an HP Notebook 15-ay011nr.
Before disassembling the computer, follow these steps:
Shut down the computer
Disconnect all external devices connected to the computer
Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
To remove the battery:
Position the computer upside down on a flat surface
Slide the battery lock latch (1)
Slide the battery release latch (2)
Remove the battery (3) from the computer
ある他の人がこのガイドを完成しました。
