HP Envy 17-J013CL WLAN Module Replacement
はじめに
手順 1 に進むThe WLAN module works the wifi that comes and goes from the laptop. So replacing this whenever goes faulty is important and thankfully is easy to fix! Be sure to keep yourself grounded to eliminate static!
必要な工具と部品
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
ある他の人がこのガイドを完成しました。
