HP Elitebook x360 1040 G5 Touchpad Replacement
はじめに
手順 1 に進むThis guide provides detailed instructions to replace your laptops touchpad. You may want to do this replacement if your touchpad does not respond or malfunctions in some other way.
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
ある他の人がこのガイドを完成しました。
