メインコンテンツにスキップ
HP Elitebook Folio 9470m Keyboard Replacement
Kenneth Bowers
Kenneth Bowers とその他 7 人の作成者
最終更新日: December 15, 2023
20分
中レベル
Your keyboard is an important part of your computer, so when it's not working properly and responding the way you're used to, it's only natural that you want to replace it as soon as possible.
On a desktop computer, if the keyboard is completely unresponsive, it will definitely need to be replaced.
However, keyboard problems can physical or digital via drivers. Windows and your keyboard may have a complicated relationship, and if your keyboard has multimedia buttons to adjust the volume or open web pages, you probably have specific software installed called a keyboard driver. If the controller fails, the keyboard will not work properly - but this is not a sign that the keyboard needs to be replaced. Downloading a new keyboard driver from the manufacturer's website will solve most problems. You don't need a new keyboard for this, just new software.
必要な工具と部品
ツール
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 手順 1、 3の画像 1 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 手順 1、 3の画像 2 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: 手順 1、 3の画像 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: 手順 2、 2の画像 1 HP Elitebook Folio 9470m Keyboard Replacement: 手順 2、 2の画像 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: 手順 3、 3の画像 1 HP Elitebook Folio 9470m Keyboard Replacement: 手順 3、 3の画像 2 HP Elitebook Folio 9470m Keyboard Replacement: 手順 3、 3の画像 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: 手順 4、 3の画像 1 HP Elitebook Folio 9470m Keyboard Replacement: 手順 4、 3の画像 2 HP Elitebook Folio 9470m Keyboard Replacement: 手順 4、 3の画像 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: 手順 6、 3の画像 1 HP Elitebook Folio 9470m Keyboard Replacement: 手順 6、 3の画像 2 HP Elitebook Folio 9470m Keyboard Replacement: 手順 6、 3の画像 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: 手順 7、 2の画像 1 HP Elitebook Folio 9470m Keyboard Replacement: 手順 7、 2の画像 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Kenneth Bowers
メンバー登録日: 04/08/16
1,432 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018人のメンバー
UMASSD-VALLIERE-F18S1G1
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 38
今までの合計 5,752
