メインコンテンツにスキップ
HP Elitebook 8460p Keyboard Replacement
Garrett Anderson
Garrett Anderson とその他 人の作成者
最終更新日: December 6, 2019
30分
中レベル
If the keyboard is bad or malfunctioning, use this guide to replace the keyboard or check the keyboard connections on the inside of the laptop.
This guide requires a bit of prying to unsnap the keyboard from the laptop chassis. Following the instructions, pry carefully and do not force anything to avoid breaking any components.
The keyboard has two electrical connectors that attach to the motherboard. Before touching the connectors, make sure you are properly grounded to avoid damaging the motherboard itself.
To complete this guide you will need a Phillips #0 screw driver; an ESD strap; and a thin, sturdy plastic pry tool.
必要な工具と部品
パーツ
ツール
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
もっと見る
  1. HP Elitebook 8460p Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Keyboard Replacement: 手順 2、 1の画像 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Keyboard Replacement, Back Panel: 手順 3、 1の画像 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Keyboard Replacement: 手順 4、 1の画像 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Keyboard Replacement, Keyboard: 手順 5、 3の画像 1 HP Elitebook 8460p Keyboard Replacement, Keyboard: 手順 5、 3の画像 2 HP Elitebook 8460p Keyboard Replacement, Keyboard: 手順 5、 3の画像 3
    • Attach ESD strap around your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
  6. HP Elitebook 8460p Keyboard Replacement: 手順 6、 1の画像 1
    • Flip the laptop over and open the screen.
  7. HP Elitebook 8460p Keyboard Replacement: 手順 7、 3の画像 1 HP Elitebook 8460p Keyboard Replacement: 手順 7、 3の画像 2 HP Elitebook 8460p Keyboard Replacement: 手順 7、 3の画像 3
    • Using a spudger, work around the edge of the keyboard and pry it up from the device.
  8. HP Elitebook 8460p Keyboard Replacement: 手順 8、 2の画像 1 HP Elitebook 8460p Keyboard Replacement: 手順 8、 2の画像 2
    • Lift the keyboard out of the laptop and flip it over.
    • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
  9. HP Elitebook 8460p Keyboard Replacement: 手順 9、 2の画像 1 HP Elitebook 8460p Keyboard Replacement: 手順 9、 2の画像 2
    • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
    • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
  10. HP Elitebook 8460p Keyboard Replacement: 手順 10、 2の画像 1 HP Elitebook 8460p Keyboard Replacement: 手順 10、 2の画像 2
    • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Garrett Anderson
メンバー登録日: 09/16/19
2,250 ポイント
10のガイドは作成済み
チーム
2 件のコメント
There's a third keyboard screw right beside the fan
Colin Chaplin - 返信
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 23
過去 30 日: 42
今までの合計 4,148
