はじめに
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the earpiece speaker in your Google Pixel Fold.
必要な工具と部品
Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
While you're waiting for the adhesive to soften, note the following:
The adhesive is under the dark black border surrounding the screen.
Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the opening pick in the bottom right corner before continuing.
Rotate the opening pick around the bottom right corner to separate the adhesive.
Insert a new opening pick in the bottom right corner.
Slide the opening pick toward the top right corner to separate the adhesive.
Leave the opening pick in the top right corner before continuing.
Rotate the opening pick around the top right corner to separate its adhesive.
Insert a new opening pick in the top right corner.
Slide the opening pick toward the top left corner to separate its adhesive.
Angle your pick so it's as flat as possible to the screen.
Rotate the opening pick around the top left corner to separate the adhesive.
Insert a new opening pick in the top left corner.
Slide the opening pick toward the bottom left corner to separate the adhesive.
Rotate the opening pick around the bottom left corner to separate the adhesive.
There's a small adhesive strip that secures the screen near the top right corner of the phone.
Heat an iOpener and apply it to the top right corner of the screen for two minutes.
Insert an opening pick under the right edge of the screen, near the top right corner.
Push the opening pick under the screen as far you can go without losing your grip.
Swing the left edge of the screen up and over the right edge of the phone.
Let the screen rest next to the phone before continuing.
この手順で使用する道具:FixMat$31.41
Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
この手順で使用する道具:Tweezers$4.99
Use tweezers, or your fingers, to remove the bottom bracket.
Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
Pry up to disconnect the screen press connector.
Remove the screen.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
この手順で使用する道具:Tesa 61395 Tape$5.99
If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
Follow this guide to replace your screen adhesive.
Use a Torx Plus 3IP screwdriver to remove the three 2.5 mm‑long screws securing the top bracket.
There's a magnet at the top right corner of phone. As you remove nearby screws, they might stick the magnet.
Pull the top bracket toward the left edge of the phone to separate it from its recess in the frame.
Remove the top bracket.
Insert the flat end of a spudger between the battery and the bottom edge of the top speaker.
Twist the spudger to separate the adhesive securing the bottom speaker.
Remove the top speaker.
Use the flat end of spudger to pry up and disconnect the top interconnect cable press connector.
Pull the upper board toward the bottom of the phone to separate it from its recess in the frame
Remove the upper board.
Insert the flat end of a spudger under the bottom of the detune board.
Twist the spudger to separate the board from its metal clip.
Remove the detune board.
Angle the detune board downward against the right edge of the frame.
Press the board against the right edge of the frame to engage its spring connector.
Press downward to slot the board into its clip and secure it to the frame.
Heat an iOpener and apply it to the earpiece speaker for two minutes.
Insert the flat end of a spudger between the frame and the bottom of the earpiece speaker.
Twist the spudger to separate the adhesive under the body of the earpiece speaker.
Grab the right edge of the earpiece speaker and pull it away from the frame to separate the connector adhesive.
Remove the earpiece speaker.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
