Giant Iguana Mountain Bike Front Brake Cable Replacement
はじめに
手順 1 に進むSometimes you may need to replace your bike brake cables when they become frayed, rigid, or no longer fit for use. This guide will show you how to replace the front brake cable of a Giant Iguana Mountain bike. You should exercise caution when using cable cutters, but otherwise, no special skills are needed or hazards to look out for. From the time you start the repair to the time you complete it, your front brake will be completely unusable. Ensure you have the time to finish before you need to ride again.
必要な工具と部品
パーツ
ツール
もっと見る
Using your hex screwdriver, loosen this bolt to release the clamp, allowing the brake cable to be removed from the caliper.
