メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin DriveSmart 55 EX Motherboard Replacement
必要な工具と部品
    1. Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin DriveSmart 55 EX Motherboard Replacement: 手順 2、 3の画像 1 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 2、 3の画像 2 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 2、 3の画像 3
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin DriveSmart 55 EX Motherboard Replacement: 手順 3、 2の画像 1 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 3、 2の画像 2
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin DriveSmart 55 EX Motherboard Replacement: 手順 4、 2の画像 1 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 4、 2の画像 2
      • Desolder the three solder points with a soldering iron to disconnect the wires from the motherboard.
      • Be careful when using the soldering iron, the tip is hot to the touch and can damage the motherboard or other surfaces when held or placed on them.
      FixBotに聞いてみる
      コメントを追加
    5. Garmin DriveSmart 55 EX Motherboard Replacement: 手順 5、 3の画像 1 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 5、 3の画像 2 Garmin DriveSmart 55 EX Motherboard Replacement: 手順 5、 3の画像 3
      • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
      • Be careful when removing the ribbon cable because it is thin and can tear easily.
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
    6. Garmin DriveSmart 55 EX Motherboard Replacement: 手順 6、 1の画像 1
      • Remove the motherboard from the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Jacob Behnke
メンバー登録日: 03/11/26
707 ポイント
4のガイドは作成済み
チーム
Purdue University Northwest, Team 7-1, Dieterle Spring 2026 Purdue University Northwest, Team 7-1, Dieterle Spring 2026人のメンバー
PNW-DIETERLE-S26S7G1
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 112
