メインコンテンツにスキップ
Fitbit Charge HR Battery Replacement
martysummer
martysummer とその他 11 人の作成者
最終更新日: January 18, 2025
50分
中レベル
コミュニティメンバーによる寄稿ガイド
This is a simple tear down & repair tutorial for the Fitbit Charge HR. Illustrated is the replacing of a weak or dead battery.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: 手順 1、 2の画像 1 Fitbit Charge HR Battery Replacement, Fitbit Charge HR weak Battery Repair / Replacement tutorial: 手順 1、 2の画像 2
    • Inside your Fitbit Charge HR
  2. Fitbit Charge HR Battery Replacement, Tools needed to replace Fitbit Charge HR battery: 手順 2、 1の画像 1
    • You'll need some plastic bits to separate the band, plus a torx T3 driver, new battery and a soldering iron.
  3. Fitbit Charge HR Battery Replacement: 手順 3、 1の画像 1
    • This repair only works on the Fitbit Charge HR model, not the older Charge without heart rate. The batteries are different.
  4. Fitbit Charge HR Battery Replacement, Separate the band from the electronics casing: 手順 4、 1の画像 1
    • Start by removing the 4 torx screws
  5. Fitbit Charge HR Battery Replacement, Take your time and be careful of the fragile plastic: 手順 5、 1の画像 1
    • The assembly is briskly snapped into place. You'll need to separate the sides of the housing with a small plastic tool and your finger nail (or two plastics). Be careful, as the housing can fracture with too much force.
  6. Fitbit Charge HR Battery Replacement, A small torx driver is required.: 手順 6、 2の画像 1 Fitbit Charge HR Battery Replacement, A small torx driver is required.: 手順 6、 2の画像 2
    • Once removed, there are 2 torx screws holding the circuit board in place. Remove these, and carefully pry the board out
  7. Fitbit Charge HR Battery Replacement, Prepare to solder!: 手順 7、 2の画像 1 Fitbit Charge HR Battery Replacement, Prepare to solder!: 手順 7、 2の画像 2
    • The Fitbit is very light and hard to hold, so it is recommended to tape the board in place when soldering.
  8. Fitbit Charge HR Battery Replacement, Understand the risk to your device.: 手順 8、 1の画像 1
    • Note: You can permanently damage your device. Be careful with the assembly, and splice one or both wires before removing the old battery to prevent a short. Do not mistake the round buzzer for a battery. It is not !
  9. Fitbit Charge HR Battery Replacement, Test your work before you re-assemble.: 手順 9、 1の画像 1
    • After replacing the bad battery, plug in the charger for at least 20 minutes. Then remove the charger to confirm you have a working replacement.
終わりに
33 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
martysummer
メンバー登録日: 02/18/13
943 ポイント
1ガイドが承認済み
22 件のコメント
if you have the manual dexterity and intellect to replace the battery on a Fit bit Charge HR, why can't you do it on. "Charge" plain model I have 3 of these with dead batteries?
coljwm - 返信
The battery on the original Fitbit tracker is different than the newer Fitbit HR. If you can find a battery that fits, it would work.
martysummer - 返信
Where can I buy a replacement battery for my charge hr? Fitbit wants me to buy a new Fitbit which is inexcusable since the watch is only 16 months old
Evan - 返信
They sell them on Amazon for $10.95. Has only one review for 2 stars. Trying to decide if I should order one. Caveat emptor!
Scott McKernon -
Can you give me the size of the battery?
Bajmóczy Géza - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 81
過去 30 日: 466
今までの合計 155,692
