メインコンテンツにスキップ
Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement
Carsten Frauenheim
Carsten Frauenheim
最終更新日: June 29, 2021
45分 - 1時間
中レベル
This guide shows how to remove and replace the clutch spring in an Echo SRM-2620U Brushcutter.
  1. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: 手順 1、 3の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: 手順 1、 3の画像 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: 手順 1、 3の画像 3
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: 手順 2、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: 手順 2、 2の画像 2
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 3、 3の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 3、 3の画像 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 3、 3の画像 3
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: 手順 4、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: 手順 4、 2の画像 2
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 5、 3の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 5、 3の画像 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 5、 3の画像 3
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: 手順 6、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: 手順 6、 2の画像 2
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 7、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 7、 2の画像 2
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the fan cover: 手順 8、 1の画像 1
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 9、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 9、 2の画像 2
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: 手順 10、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: 手順 10、 2の画像 2
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Separate the shaft from the engine assembly: 手順 11、 1の画像 1
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 12、 3の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 12、 3の画像 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 12、 3の画像 3
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch cover: 手順 13、 1の画像 1
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 14、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 14、 2の画像 2
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch assembly: 手順 15、 1の画像 1
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 16、 2の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 16、 2の画像 2
    • Remove the clutch assembly.
  17. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: 手順 17、 3の画像 1 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: 手順 17、 3の画像 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: 手順 17、 3の画像 3
    • Firmly grip one clutch shoe in each hand and twist them apart to release the spring tension.
    • During reassembly, loop the clutch spring in place on the clutch shoes and twist them together to reapply spring tension.
    • Disconnect one side of the spring loop from one of the clutch shoes.
  18. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: 手順 18、 1の画像 1
    • Remove the spring from the remaining clutch shoe.
終わりに
Carsten Frauenheim
メンバー登録日: 03/10/20
136,034 ポイント
371のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
119 メンバー
19,479のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 191
