Dremel 4000 Power Cord Replacement
はじめに
手順 1 に進むIn the following steps you will access the electrical assembly, and remove the positive and negative wires that connect the power cord to the assembly.
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
5 の人々がこのガイドを完成させました。
