メインコンテンツにスキップ
Dissasembling Nokia 8290 Charging Port
Parker Niebauer
Parker Niebauer とその他 5 人の作成者
最終更新日: May 7, 2024
1 - 2 分
中レベル
Installing a new charging port may be necessary if you are having trouble charging your battery. Installation should only be done as a last resort, after trying other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone charging ports.
必要な工具と部品
ツール
  1. Dissasembling Nokia 8290 Charging Port, Front Cover: 手順 1、 3の画像 1 Dissasembling Nokia 8290 Charging Port, Front Cover: 手順 1、 3の画像 2 Dissasembling Nokia 8290 Charging Port, Front Cover: 手順 1、 3の画像 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: 手順 2、 3の画像 1 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: 手順 2、 3の画像 2 Dissasembling Nokia 8290 Charging Port, Installing Nokia 8290 Charging Port: 手順 2、 3の画像 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Dissasembling Nokia 8290 Charging Port: 手順 3、 3の画像 1 Dissasembling Nokia 8290 Charging Port: 手順 3、 3の画像 2 Dissasembling Nokia 8290 Charging Port: 手順 3、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the indicated part.
    • The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm.
  4. Dissasembling Nokia 8290 Charging Port: 手順 4、 3の画像 1 Dissasembling Nokia 8290 Charging Port: 手順 4、 3の画像 2 Dissasembling Nokia 8290 Charging Port: 手順 4、 3の画像 3
    • There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well.
    • The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm.
  5. Dissasembling Nokia 8290 Charging Port: 手順 5、 3の画像 1 Dissasembling Nokia 8290 Charging Port: 手順 5、 3の画像 2 Dissasembling Nokia 8290 Charging Port: 手順 5、 3の画像 3
    • After removing the two parts, locate the charging port.
    • Use tweezers to remove the charging port.
終わりに
作成者
5人の作成者と共同で作成されました。
Parker Niebauer
メンバー登録日: 10/22/12
7 ポイント
6のガイドは作成済み
チーム
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S15G3
3 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 432
