メインコンテンツにスキップ
Disassembling Nokia 3100b Speaker
Sterling Fuentes
Sterling Fuentes とその他 2 人の作成者
最終更新日: January 28, 2014
見積もりなし
中レベル
アクションショット
作成中の学生
空欄の手順
ステップトリマー
This guide shows you how to access the speaker of your phone, the component which produces sound.
必要な工具と部品
  1. Disassembling Nokia 3100b Speaker, Battery: 手順 1、 1の画像 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Speaker: 手順 2、 1の画像 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Speaker, SIM Card: 手順 3、 1の画像 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Speaker: 手順 4、 1の画像 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Speaker, Screen: 手順 5、 1の画像 1
    • Separate the front cover from the main body of the phone.
  6. Disassembling Nokia 3100b Speaker: 手順 6、 1の画像 1
    • Remove the six screws along the edges of the phone.
  7. Disassembling Nokia 3100b Speaker: 手順 7、 1の画像 1
    • Pull the screen assembly from the base of the phone.
  8. Disassembling Nokia 3100b Speaker: 手順 8、 1の画像 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Disassembling Nokia 3100b Speaker: 手順 9、 1の画像 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Disassembling Nokia 3100b Speaker: 手順 10、 1の画像 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Disassembling Nokia 3100b Speaker: 手順 11、 1の画像 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
  12. Disassembling Nokia 3100b Speaker, Speaker: 手順 12、 1の画像 1
    • Set the screen and the tabs aside.
  13. Disassembling Nokia 3100b Speaker: 手順 13、 1の画像 1
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
  14. Disassembling Nokia 3100b Speaker: 手順 14、 1の画像 1
    • Remove the speaker from the assembly.
終わりに
作成者
2人の作成者と共同で作成されました。
Sterling Fuentes
メンバー登録日: 04/09/10
130 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G64
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,221
