メインコンテンツにスキップ
Disassembling Nokia 2366i Main Display
Michael Machado
Michael Machado とその他 6 人の作成者
最終更新日: September 9, 2017
見積もりなし
中レベル
Removing the Main Display
必要な工具と部品
ツール
  1. Disassembling Nokia 2366i Main Display, Battery: 手順 1、 2の画像 1 Disassembling Nokia 2366i Main Display, Battery: 手順 1、 2の画像 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Main Display: 手順 2、 1の画像 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Main Display: 手順 3、 3の画像 1 Disassembling Nokia 2366i Main Display: 手順 3、 3の画像 2 Disassembling Nokia 2366i Main Display: 手順 3、 3の画像 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Main Display, Front Cover: 手順 4、 1の画像 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Main Display: 手順 5、 2の画像 1 Disassembling Nokia 2366i Main Display: 手順 5、 2の画像 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Main Display: 手順 6、 2の画像 1 Disassembling Nokia 2366i Main Display: 手順 6、 2の画像 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Main Display, Main Display: 手順 7、 2の画像 1 Disassembling Nokia 2366i Main Display, Main Display: 手順 7、 2の画像 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Main Display: 手順 8、 2の画像 1 Disassembling Nokia 2366i Main Display: 手順 8、 2の画像 2
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Main Display: 手順 9、 3の画像 1 Disassembling Nokia 2366i Main Display: 手順 9、 3の画像 2 Disassembling Nokia 2366i Main Display: 手順 9、 3の画像 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
終わりに
作成者
6人の作成者と共同で作成されました。
Michael Machado
メンバー登録日: 01/21/11
334 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G14
5 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 1,090
