メインコンテンツにスキップ
Disassembling Motorola i265 Rear Casing/Battery/SIM Card
Jonathan Uder
Jonathan Uder とその他 3 人の作成者
最終更新日: January 28, 2014
3分
とても簡単
This repair guide will explain how to remove the rear casing of the phone, the battery, and the SIM card.
必要な工具と部品
ツール
  • Spudger
    Spudger
  1. Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: 手順 1、 2の画像 1 Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: 手順 1、 2の画像 2
    • Press thumb against the top of the rear casing as shown and push down as you slide the casing off of the body.
    • You should hear a click as the latches on the casing disengage.
  2. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 2、 3の画像 1 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 2、 3の画像 2 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 2、 3の画像 3
    • To remove the battery, press thumb against the bottom edge of the battery and push towards the top of the phone.
    • Then, lift the bottom edge of the battery upwards out of the body. Gently pull the battery towards yourself, and out of the phone.
  3. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 3、 3の画像 1 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 3、 3の画像 2 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 手順 3、 3の画像 3
    • To remove SIM card, press thumb against tab marked “PUSH.”
    • While still pressing the PUSH tab, gently press spduger into the groove between the top of the SIM card and the body. Use spudger to slide SIM card toward the PUSH tab, so that when the spudger reaches the metal cover, the card itself is depressing the tab.
    • Press your thumb against the exposed section of the SIM card, and slide it towards the rear of the phone until it is completely free of the metal cover.
終わりに
作成者
3人の作成者と共同で作成されました。
Jonathan Uder
メンバー登録日: 04/15/10
1 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-15, Maness Spring 2010 Cal Poly, Team 6-15, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S6G15
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 2,575
