Disassembling Canon PowerShot S50 Outer Casing
15 - 20 分
中レベル
はじめに
手順 1 に進むUse this guide to remove the back panel of the camera.
必要な工具と部品
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
Place camera LCD side up and press up on the battery door.
Let it swing open until you can see the battery inside.
Look at the camera from the side with the lanyard and 4 screws.
Remove the two 3.4 mm screws on the metallic colored part.
Using a spudger, gently separate the back panel from the rest of the camera and remove it.
もう少しです!
終わりに
