メインコンテンツにスキップ
Lenovo Ideapad C340-14API or Flex 14-API Disassembly
Arijit Guha
Arijit Guha とその他 人の作成者
最終更新日: September 25, 2024
見積もりなし
中レベル
コミュニティメンバーによる寄稿ガイド
  1. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Take out the screws: 手順 1、 1の画像 1
    • Take out the 10 Torx T6 screws as marked and pry open the back cover. I pried from the top (midpoint of the chassis in between the two hinges) as it felt easier that way. You can use a prying tool for completion of this step.
  2. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Component and connections identification: 手順 2、 3の画像 1 Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Component and connections identification: 手順 2、 3の画像 2 Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Component and connections identification: 手順 2、 3の画像 3
    • All parts have been identified on the photos.
  3. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Battery details: 手順 3、 1の画像 1
    • Battery details: 2965 mAh/45Wh, 15.36V - 17.6V
  4. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Disconnect battery: 手順 4、 1の画像 1
    • Disconnect battery as shown. This is a very important step before doing any upgrades or further disassembly
  5. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, RAM upgrade/replacement: 手順 5、 3の画像 1 Lenovo Ideapad C340-14API or Flex 14-API Disassembly, RAM upgrade/replacement: 手順 5、 3の画像 2 Lenovo Ideapad C340-14API or Flex 14-API Disassembly, RAM upgrade/replacement: 手順 5、 3の画像 3
    • Take out the metal shield. You can use a prying tool to take it out. Once out, you should be able to see the RAM and the connector.
    • Removing the RAM is easy. You will need both your hands. Gently push the metal prongs outside of the RAM as shown with yellow markers and the RAM should pop out upwards. Once done, gently pull it out of the socket.
    • For installation of new RAM, insert the RAM at a 45 degree angle into the socket and push it down until the metal prongs click it back in.
  6. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, Factory RAM details: 手順 6、 1の画像 1
    • The RAM is from Samsung and the spec is DDR4 2666 MHz. My unit came with 8 GB of RAM (4 GB soldered on board and 4 GB on an user upgrade-able stick).
    • It is surprising to see that though the AMD Ryzen 5 3500U supports up to 2400 MHz DDR4 RAM, Lenovo is using 2666 MHz RAM on it. The memory operates at 2400 MHz only which can be seen from CPU-Z or other similar software.
  7. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, SSD replacement/upgrade/factory SSD details: 手順 7、 1の画像 1
    • Lenovo has used a Samsung PM981 NVMe SSD. My variant came with a 1 TB one.
    • Lenovo has used a warranty seal and hence they will know if the SSD has been removed.
    • Replacement is pretty straight forward, Once the screw is out, lift the SSD gently and pull it out. Reverse the procedure to install another SSD.
  8. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, CPU heatsink removal for thermal paste replacement/cleaning: 手順 8、 1の画像 1
    • Take out the three screws as shown and gently take the heatsink out. Do not force the heatsink out as the existing thermal paste will cause some adhesion.
  9. Lenovo Ideapad C340-14API or Flex 14-API Disassembly, CPU details/thermal paste application: 手順 9、 2の画像 1 Lenovo Ideapad C340-14API or Flex 14-API Disassembly, CPU details/thermal paste application: 手順 9、 2の画像 2
    • Clean the existing thermal paste from CPU and bottom of the heatsink. You can use IPA and some Qtips for the procedure.
    • My unit came with an AMD Ryzen 5 3500U quad core CPU with 8 threads
    • After completion of thermal paste application, follow steps in reverse.
    • Before connecting the battery, make sure everything on the motherboard is connected. Before you connect the battery, you should have completed all the tasks (reinstall CPU heatsink, install memory and the shield and plug in any other cables you removed)
終わりに
10 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Arijit Guha
メンバー登録日: 10/22/16
855 ポイント
2のガイドは作成済み
13 件のコメント
Hi, I wanted to replace My motherboard. what more do I need to get the keyboard out.
I want to know everything before I start dissembling anything.
Rujul Rumale - 返信
Hi, I did not get to the keyboard but from what I believe is that the keyboard is riveted with plastic tabs or secured with screws (unlikely) with the palmrest. You need to take out the battery and the motherboard and then need to remove the insulation to expose the tabs. Then using a precision knife, you need to cut off those plastic tabs and the keyboard out. For securing the new keyboard, you can use some plastic and melt them with a soldering iron so that the keyboard stays flat. The best solution is to get the entire palmrest section as replacement with the keyboard attached.
Arijit Guha -
I had a coworker spill apple juice over his keyboard. Unfortunately the whole C-Cover had to be replaced which required a complete disassambly. You have to take everything apart.
Fred -
which size of the t6 screw at the back cover they are using ?
long yap - 返信
The screws should be about 2.5 cm.
Arijit Guha -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 51
過去 30 日: 217
今までの合計 13,402
