メインコンテンツにスキップ
Dell XPS 15-L502X Front Cover Replacement
Kyle Compton
Kyle Compton とその他 7 人の作成者
最終更新日: September 14, 2020
5 - 30 分
簡単
アクションショット
This guide will help you remove the front panel of your laptop. Removing the front panel can expose many delicate components of the laptop, so it's important to be gentle and cautious of static when working through this guide.
必要な工具と部品
ツール
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell XPS 15-L502X Front Cover Replacement, Front Cover: 手順 1、 1の画像 1
    • Before prying up on the cover, you may have to first remove a screw located inside the battery compartment (M2X3) and release the two latches. If you don't release the latches, you may snap the cover.
    • Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
    • Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
    • Cracking sounds are normal. Be careful and take your time removing this panel.
  2. Dell XPS 15-L502X Front Cover Replacement: 手順 2、 1の画像 1
    • Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
    • The mouse pad is connected to the rest of the computer via two cables underneath the cover. These cables must be unhooked before the cover can be completely removed.
  3. Dell XPS 15-L502X Front Cover Replacement: 手順 3、 2の画像 1 Dell XPS 15-L502X Front Cover Replacement: 手順 3、 2の画像 2
    • Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
    • Releasing these cables can be done by hand or by using a spudger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Kyle Compton
メンバー登録日: 09/16/15
416 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-3, Baechle Fall 2015 IUPUI, Team 2-3, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S2G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 21
今までの合計 2,905
