Dell XPS 15 L521X WiFi Card Replacement
3分
中レベル
はじめに
手順 1 に進むThis guide will help you replace the Wifi card on your Dell XPS. The Wifi card is known to fail in the Dell XPS, so this easy repair should fix that. This guide will only require you to remove one screw, and pull the Wifi Card out of place.
必要な工具と部品
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
もう少しです!
終わりに
