メインコンテンツにスキップ
Dell XPS 15 9570 Keyboard Replacement
Sophie
Sophie とその他 5 人の作成者
最終更新日: April 15, 2024
2時間
中レベル
アクションショット
多くの画像が必要
Use this guide to learn the steps to remove the keyboard of your Dell XPS 15 9570. The keyboard is an input device used to enter characters and functions into your computer system by pressing the keys.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell XPS 15 9570 Keyboard Replacement, Base Cover: 手順 1、 1の画像 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Keyboard Replacement: 手順 3、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 3、 2の画像 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Keyboard Replacement: 手順 4、 1の画像 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Keyboard Replacement, Battery: 手順 5、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
    For laptops with the larger battery, there are actually 9 screws to remove.
    nebman227 - 返信
    My previous comment is incorrect, it is 7 screws, not 9, for the larger battery
    nebman227 - 返信
    in the red circles wrong screws marked.
    Eugenio Rodriguez - 返信
    Is this 9570 model in previous guide you have 91wh and here you showing 56wh battery which is for xps15 9560 I will open myself mine before ordering replacement as your photos presenting model 60' not 70'
    Belliah - 返信
  6. Dell XPS 15 9570 Keyboard Replacement: 手順 6、 1の画像 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Keyboard Replacement: 手順 7、 1の画像 1
    • With your hands, pick up and remove the battery from the system.
    Just right except my battery was full width.
    William Corwin - 返信
  8. Dell XPS 15 9570 Keyboard Replacement, Heat Sink: 手順 8、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Heat Sink: 手順 8、 2の画像 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Keyboard Replacement: 手順 9、 1の画像 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Keyboard Replacement, Fan: 手順 10、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Fan: 手順 10、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Keyboard Replacement: 手順 11、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Keyboard Replacement: 手順 12、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 12、 2の画像 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Keyboard Replacement: 手順 13、 1の画像 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Keyboard Replacement, RAM: 手順 14、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, RAM: 手順 14、 2の画像 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Keyboard Replacement: 手順 15、 1の画像 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Keyboard Replacement, SSD: 手順 16、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, SSD: 手順 16、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Keyboard Replacement: 手順 17、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 17、 2の画像 2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Keyboard Replacement, Wireless Card: 手順 18、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Wireless Card: 手順 18、 2の画像 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Keyboard Replacement: 手順 19、 1の画像 1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Keyboard Replacement: 手順 20、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 20、 2の画像 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Keyboard Replacement: 手順 21、 1の画像 1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Keyboard Replacement, Keyboard: 手順 22、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Keyboard: 手順 22、 2の画像 2
    • Disconnect the two motherboard cables using the opening tool.
  23. Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Keyboard Replacement: 手順 25、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 25、 2の画像 2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  26. Dell XPS 15 9570 Keyboard Replacement: 手順 26、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 26、 2の画像 2
    • Disconnect the keyboard cables, labeled BL and KB, using the opening tool.
  27. Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 3
    • Unscrew the 1.9mm screws using a Phillips #00 screwdriver.
    • Flip the cutouts on the keyboard to reveal and unscrew remaining 1.9mm screws underneath.
    • Remove the keyboard.
    A #00 is too large. It needs to be a #000 screwdriver.
    Christian Kryger - 返信
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sophie
メンバー登録日: 11/09/23
301 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-1, Harley Fall 2023 IUPUI, Team 3-1, Harley Fall 2023人のメンバー
IUPUI-HARLEY-F23S3G1
4 メンバー
3のガイドは作成済み
コメント 1 件
Thanks alot.
Motherboard: 2 more cables to disconnect.
Keyboard backside some more screws to remove.
Mister Iks - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 30
過去 30 日: 98
今までの合計 1,401
