メインコンテンツにスキップ
Dell XPS 15 9560 Motherboard Replacement
Jada Houser
Jada Houser とその他 4 人の作成者
最終更新日: December 28, 2021
40分 - 1時間
中レベル
アクションショット
多くの画像が必要
作成中の学生
高画質の画像が必要
If your Dell XPS 15 9560 boots up with the BIOS menu, produces a beeping pattern upon failure to boot, or has been experiencing hardware and software malfunctioning with all other fixes ruled out, there may be an irreparable issue with the motherboard and it will need to be replaced.
The motherboard is the central hub of the laptop. It distributes power throughout the laptop and allows the laptop’s hardware components to communicate with the processor.
Damage to a laptop’s body or damage by liquids leaking into a laptop can lead to a damaged motherboard. A motherboard may also fail over time as it ages. This is the worst case scenario for many laptops as a damage motherboard means the entire computer is no longer operable.
Before beginning, backup all important files to an external hard drive or a USB. Additionally, make sure the laptop is off and the laptop is disconnected from any power source.
必要な工具と部品
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Motherboard Replacement: 手順 2、 1の画像 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Motherboard Replacement: 手順 3、 1の画像 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Motherboard Replacement: 手順 4、 1の画像 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Motherboard Replacement, Battery: 手順 5、 1の画像 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the battery.
  8. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: 手順 8、 1の画像 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): 手順 10、 1の画像 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: 手順 11、 1の画像 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  12. Dell XPS 15 9560 Motherboard Replacement: 手順 12、 1の画像 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  13. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: 手順 13、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  14. Dell XPS 15 9560 Motherboard Replacement: 手順 14、 1の画像 1
    • Disconnect the wireless card cables from the wireless card.
  15. Dell XPS 15 9560 Motherboard Replacement: 手順 15、 1の画像 1
    • Slide the wireless card out of its slot.
  16. Dell XPS 15 9560 Motherboard Replacement, Fans: 手順 16、 1の画像 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  17. Dell XPS 15 9560 Motherboard Replacement: 手順 17、 1の画像 1
    • Unplug the fan cable.
  18. Dell XPS 15 9560 Motherboard Replacement: 手順 18、 1の画像 1
    • Carefully remove the left-side fan.
  19. Dell XPS 15 9560 Motherboard Replacement: 手順 19、 1の画像 1
  20. Dell XPS 15 9560 Motherboard Replacement: 手順 20、 1の画像 1
    • Remove the right-side fan.
  21. Dell XPS 15 9560 Motherboard Replacement, RAM: 手順 21、 2の画像 1 Dell XPS 15 9560 Motherboard Replacement, RAM: 手順 21、 2の画像 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  22. Dell XPS 15 9560 Motherboard Replacement, Motherboard: 手順 22、 1の画像 1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  23. Dell XPS 15 9560 Motherboard Replacement: 手順 23、 1の画像 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  24. Dell XPS 15 9560 Motherboard Replacement: 手順 24、 1の画像 1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  25. Dell XPS 15 9560 Motherboard Replacement: 手順 25、 1の画像 1
    • Remove the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jada Houser
メンバー登録日: 09/28/21
839 ポイント
7のガイドは作成済み
チーム
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S4G5
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 55
今までの合計 4,387
