メインコンテンツにスキップ
Dell Vostro V13  Back Cover and Battery Removal
Patrick Swaney
Patrick Swaney とその他 2 人の作成者
最終更新日: July 1, 2019
5 - 10 分
中レベル
This is a prerequisite guide on how to remove the back cover and the battery of the Dell Vostro V13. It will allow you to work on the laptop safely. Also be sure to power down, unplug and back up your laptop in order to prevent injury and data loss.
必要な工具と部品
ツール
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 手順 1、 3の画像 1 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 手順 1、 3の画像 2 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 手順 1、 3の画像 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: 手順 2、 3の画像 1 Dell Vostro V13  Back Cover and Battery Removal: 手順 2、 3の画像 2 Dell Vostro V13  Back Cover and Battery Removal: 手順 2、 3の画像 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: 手順 3、 3の画像 1 Dell Vostro V13  Back Cover and Battery Removal: 手順 3、 3の画像 2 Dell Vostro V13  Back Cover and Battery Removal: 手順 3、 3の画像 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: 手順 4、 2の画像 1 Dell Vostro V13  Back Cover and Battery Removal: 手順 4、 2の画像 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: 手順 5、 3の画像 1 Dell Vostro V13  Back Cover and Battery Removal: 手順 5、 3の画像 2 Dell Vostro V13  Back Cover and Battery Removal: 手順 5、 3の画像 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: 手順 6、 2の画像 1 Dell Vostro V13  Back Cover and Battery Removal: 手順 6、 2の画像 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
終わりに
作成者
2人の作成者と共同で作成されました。
Patrick Swaney
メンバー登録日: 01/16/19
363 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team S2-G1, Bedsole Spring 2019 University of Alabama, Team S2-G1, Bedsole Spring 2019人のメンバー
UA-BEDSOLE-S19S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 28
今までの合計 429
