メインコンテンツにスキップ
Dell Vostro A860 Keyboard Replacement
Joshua Dennis
Joshua Dennis とその他 人の作成者
最終更新日: May 25, 2016
6分
簡単
Careful not to mix the screw sizes, some may be too shallow or too deep if inserted into the wrong holes upon reassembly. The keyboard is a single unit and is removed as one piece at the appropriate step.
必要な工具と部品
ツール
  1. Dell Vostro A860 Keyboard Replacement, Keyboard: 手順 1、 2の画像 1 Dell Vostro A860 Keyboard Replacement, Keyboard: 手順 1、 2の画像 2
    • Make sure the computer is powered down before beginning your work
    • Remove the battery and set it aside, there is a small clip that slides to free the battery.
    • Unscrew the two 4.7mm screws below the battery.
  2. Dell Vostro A860 Keyboard Replacement: 手順 2、 2の画像 1 Dell Vostro A860 Keyboard Replacement: 手順 2、 2の画像 2
    • Remove seven 8.6mm screws from the left and right side of the battery compartment
    • There are 2 screws to the left of the compartment, 3 to the right, and 2 along the bottom side.
  3. Dell Vostro A860 Keyboard Replacement: 手順 3、 3の画像 1 Dell Vostro A860 Keyboard Replacement: 手順 3、 3の画像 2 Dell Vostro A860 Keyboard Replacement: 手順 3、 3の画像 3
    • Flip the laptop over and open it up.
    • Using a plastic opening tool carefully pry up along the edge of the plastic bezel at the top of the keyboard.
    • Getting the lip of the plastic opening tool under the edge of the bezel and moving it along the right and left edges helps to make removal easier.
  4. Dell Vostro A860 Keyboard Replacement: 手順 4、 2の画像 1 Dell Vostro A860 Keyboard Replacement: 手順 4、 2の画像 2
    • Remove two 5.5mm screws from the top of the keyboard
    • Using a plastic opening tool push inward along the edges of the keyboard to release the holding clips
  5. Dell Vostro A860 Keyboard Replacement: 手順 5、 1の画像 1
    • Lift the keyboard upwards
    • Be careful not to pull too hard on the keyboard as it is still attached to the laptop by the ribbon connector.
    • Using the plastic opening tool push up on the black clip holding the connector ribbon.
    • Pull out the ribbon connector to remove the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Joshua Dennis
メンバー登録日: 03/25/16
528 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016人のメンバー
UMASSD-MILES-S16S1G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 675
