Dell Vostro 3550 Disk Drive Tray Latch Replacement
はじめに
手順 1 に進むThis guide will guide the user through all of the necessary steps to replace the disk drive tray latch on their Dell Vostro 3550. This component may need to be replaced if the user notices that the tray will not eject or close properly. The cause of this problem is that the latch mechanism is broken inside the disk tray. This is a common problem that occurs when users close their disk drive with a lot of force.
必要な工具と部品
Push a paperclip that is bent straight into the small pin hole on the right of the release button.
When 3/4" of the paperclip is inserted the tray will pop open.
Pull the disk tray out as far as it will extend.
