Dell Vostro 15 3565 Hard Drive Bracket Replacement
必要な工具と部品
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
Remove the screws inside the palmrest [3].
Disconnect the hard drive cable from the connector on the system board [1, 2].
Remove the screws that secure the hard drive assembly to the computer [3].
Lift the hard drive assembly away from the computer [4].
Pull the hard drive cable connector to remove it from the hard drive [1].
Remove the screws that secure the hard drive bracket to the hard drive [2].
Lift the hard drive from the hard drive bracket [3].
