Dell Inspiron 3542 Hard Drive Replacement
はじめに
手順 1 に進むThis guide provides steps on how to remove and replace the hard drive for the Dell Inpiron 3542. This will allow you to carefully remove and replace your hard drive if broken, or if you want to upgrade the hard drive.
The hard drive is the device in your computer that stores and retrieves the data that you have saved. If you are running low on space, upgrading your hard drive would allow you to have more space and continue to work. If your hard drive fails, replacing your hard drive will allow you to continue using your computer.
必要な工具と部品
修理キット
キットには、この修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
Flip computer over to the bottom and slide the latches on both sides of battery outwards.
Remove the battery from computer.
ある他の人がこのガイドを完成しました。
