メインコンテンツにスキップ
Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement
Delia Padilla
Delia Padilla とその他 2 人の作成者
最終更新日: December 28, 2022
1分
簡単
The CMOS battery powers the BIOS firmware in the Dell Inspiron 17" 7786 2-in-1 laptop. When it fails, the BIOS firmware shuts down and defaults to original settings. Without a CMOS battery, the computer may not boot up at all.
If the battery is nearing its end, several things may happen. It can cause freezing, shutdowns, beeping, date and time reset, drivers disappearing, and internet connectivity.
Some other signs of a faulty CMOS battery include:
  • The keyboard may have reset to its original configuration.
  • The icons won't respond to clicks or key inputs.
  • The cursor may not be moving or responding.
  • The date and time can reset.
  • The drivers can disappear.
  • You can also have difficulties connecting to the internet.
  • The computer also freezes or restarts at random.
  • Peripherals like the keyboard, mouse and touchpad aren't responding.
There is a chance that the CMOS battery has failed. Replacing the battery is recommended in these cases.
必要な工具と部品
ツール
  1. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: 手順 1、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: 手順 1、 2の画像 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 2、 2の画像 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 3、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 3、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 3、 3の画像 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 4、 3の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 4、 3の画像 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 4、 3の画像 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: 手順 5、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: 手順 5、 2の画像 2
    • Disconnect the CMOS battery cable from the motherboard.
  6. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 6、 2の画像 1 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: 手順 6、 2の画像 2
    • The battery may have a very strong adhesive keeping it from peeling off easily.
    • Peel the battery off.
終わりに
作成者
2人の作成者と共同で作成されました。
Delia Padilla
メンバー登録日: 08/23/22
588 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022人のメンバー
GCC-CLASS-F22S1G3
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 26
今までの合計 583
