メインコンテンツにスキップ
Dell Inspiron 13 7378 Wi-Fi Card Replacement
Samantha Gonzalez
Samantha Gonzalez とその他 2 人の作成者
最終更新日: May 26, 2022
10 - 15 分
中レベル
Does your Wi-Fi from your Dell Inspiron 13 7378 not connect to a network? This guide will help you walk through replacing your Wi-Fi card and get you back on the web.
The Wi-Fi card is the part of the laptop's way of connecting to a Wi-Fi network. The Wi-Fi card is a very small 1 inch square located on the motherboard which can easily be broken if the steps are not followed correctly.
必要な工具と部品
ツール
もっと見る
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: 手順 1、 1の画像 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 2、 2の画像 1 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 2、 2の画像 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 3、 3の画像 1 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 3、 3の画像 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 3、 3の画像 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: 手順 4、 2の画像 1 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: 手順 4、 2の画像 2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 5、 1の画像 1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 手順 6、 1の画像 1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Samantha Gonzalez
メンバー登録日: 02/08/22
298 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022人のメンバー
GCC-SAKNEE-S22S1G3
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 368
