メインコンテンツにスキップ
Dell Chromebook 3100 Screen Replacement
Nickolas Delgado
Nickolas Delgado とその他 2 人の作成者
最終更新日: May 7, 2024
10 - 15 分
中レベル
コミュニティメンバーによる寄稿ガイド
In this guide I will show you how to replace the screen on a Dell 3100 Chromebook. I set this as moderate difficulty due to the strong adhesive under the screen cover. It can be tricky to remove the cover without a heat gun or blow dryer to weaken the adhesive. It's not impossible, but use caution to not damage the cover.
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Dell Chromebook 3100 Screen Replacement, Disconnect the Battery: 手順 1、 3の画像 1 Dell Chromebook 3100 Screen Replacement, Disconnect the Battery: 手順 1、 3の画像 2 Dell Chromebook 3100 Screen Replacement, Disconnect the Battery: 手順 1、 3の画像 3
    • Loosen the 9 screws from the bottom cover with the Phillips #1 screwdriver. NOTE: You don't need to fully remove the screws. They will remain attached to the cover.
    • Once all of the screws are loose, use the opening tool to pry the cover from the frame. NOTE: I like to start near the hinges as shown in the pictures. There is a gap that allows for enough leverage to open the cover.
    • Locate the ribbon connecting the battery to the main board. Firmly grip the attached fabric and pull away from the main board.
  2. Dell Chromebook 3100 Screen Replacement, Remove Screen Cover: 手順 2、 3の画像 1 Dell Chromebook 3100 Screen Replacement, Remove Screen Cover: 手順 2、 3の画像 2 Dell Chromebook 3100 Screen Replacement, Remove Screen Cover: 手順 2、 3の画像 3
    この手順で使用する道具:
    • Open the Chromebook and remove the black plastic covers over the screws. They are attached with a light coating of glue. I found that tweezers work best to get under the cover.
    • With the small covers removed, unscrew the four (4) screws holding the screen cover in place.
    • Using an opening tool, begin working on the sides of the screen cover to release the clips.
    • IMPORTANT: There is a stronger adhesive applied to the bottom part of the screen (Shown in image three under the "Dell" logo). If you have a blow dryer or heat gun, you can soften the adhesive for easier removal. Otherwise, you will need to work with a Jimmy to detach the cover.
  3. Dell Chromebook 3100 Screen Replacement, Remove Screen Screws: 手順 3、 2の画像 1 Dell Chromebook 3100 Screen Replacement, Remove Screen Screws: 手順 3、 2の画像 2
    • Remove the four (4) screws attaching the screen to the frame.
    • Lift the screen and lay it on the keyboard. Be careful not to pull the screen too far or run the risk of damaging the wires.
  4. Dell Chromebook 3100 Screen Replacement, Unplug Screen: 手順 4、 3の画像 1 Dell Chromebook 3100 Screen Replacement, Unplug Screen: 手順 4、 3の画像 2 Dell Chromebook 3100 Screen Replacement, Unplug Screen: 手順 4、 3の画像 3
    • Remove the adhesive cover to expose the connector.
    • Look for the latch that holds the connector in place. It will be marked with black and needs to be lifted to remove the connector. (Shown in the second image with the red arrow.)
    • Grip the wires and gently pull to disconnect the wires from the screen.
  5. Dell Chromebook 3100 Screen Replacement, Connect New Screen: 手順 5、 2の画像 1 Dell Chromebook 3100 Screen Replacement, Connect New Screen: 手順 5、 2の画像 2
    • Reverse the order to connect the new screen.
    • Lay the new screen back in place and screw it to the frame. Be sure to remove any plastic film on the screen before replacing the screen cover.
終わりに
To reassemble your device, follow these instructions in reverse order. Test your device and confirm it is working properly.
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nickolas Delgado
メンバー登録日: 11/04/21
518 ポイント
2のガイドは作成済み
コメント 1 件
where can i get a screen to replace the one i have?
kamaria - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 30
過去 30 日: 124
今までの合計 3,070
