メインコンテンツにスキップ
Dell Chromebook 3100 2-in-1 Battery Replacement
Maria Williams
Maria Williams とその他 4 人の作成者
最終更新日: April 5, 2023
5分
とても簡単
おすすめの学生による修理ガイド
If your Dell Chromebook 3100 2-in-1 has lost its ability to hold a charge, you most likely have a dead battery, which requires replacement. A functional battery provides power to your Chromebook. Eventually, Chromebook batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, you should replace your battery.
Caution:
  • Exercise caution when handling Lithium-ion batteries.
  • Do not crush, drop, mutilate, or penetrate the battery with foreign objects.
  • Do not apply pressure to the surface of the battery .
  • Do not use tools of any kind to pry on or against the battery.
  • If a battery gets stuck in a device as a result of swelling, do not try to free it as puncturing, bending, or crushing a Lithium-ion battery can be dangerous.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: 手順 1、 2の画像 1 Dell Chromebook 3100 2-in-1 Battery Replacement, Back Cover: 手順 1、 2の画像 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 2、 2の画像 1 Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 2、 2の画像 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: 手順 3、 2の画像 1 Dell Chromebook 3100 2-in-1 Battery Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 4、 3の画像 1 Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 4、 3の画像 2 Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 4、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 5、 2の画像 1 Dell Chromebook 3100 2-in-1 Battery Replacement: 手順 5、 2の画像 2
    • Carefully remove the battery from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Maria Williams
メンバー登録日: 09/02/21
254 ポイント
1ガイドが承認済み
チーム
Gateway, Team 1-1, Pee Fall 2021 Gateway, Team 1-1, Pee Fall 2021人のメンバー
GCC-PEE-F21S1G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 26
今までの合計 1,728
