メインコンテンツにスキップ
Dell Chromebook 13-7310 Motherboard Replacement
Brett Raymond
Brett Raymond とその他 4 人の作成者
最終更新日: June 10, 2019
15 - 25 分
中レベル
A damaged motherboard is a serious issue and can be a hassle to fix, but it doesn't have to be! By following the quick and easy motherboard replacement guide you can have your Chromebook working again in no time!
必要な工具と部品
ツール
もっと見る
  1. Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Motherboard Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Motherboard Replacement, Battery: 手順 3、 1の画像 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Motherboard Replacement: 手順 5、 1の画像 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Motherboard Replacement, Network Card: 手順 6、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement, Network Card: 手順 6、 2の画像 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Motherboard Replacement: 手順 7、 1の画像 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Motherboard Replacement: 手順 8、 1の画像 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Dell Chromebook 13-7310 Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Gently pull to unplug fan connector.
  10. Dell Chromebook 13-7310 Motherboard Replacement: 手順 10、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 10、 2の画像 2
    • Remove 4 screws securing heat sink.
  11. Dell Chromebook 13-7310 Motherboard Replacement: 手順 11、 1の画像 1
    • Lift away heat sink.
  12. Dell Chromebook 13-7310 Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Dell Chromebook 13-7310 Motherboard Replacement: 手順 13、 1の画像 1
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Dell Chromebook 13-7310 Motherboard Replacement: 手順 14、 1の画像 1
    • Gently remove the cable.
  15. Dell Chromebook 13-7310 Motherboard Replacement: 手順 15、 1の画像 1
    • Pull up on connector tab to release IO board cable.
  16. Dell Chromebook 13-7310 Motherboard Replacement: 手順 16、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 16、 2の画像 2
    • Pull up on connector tab to release touchpad cable.
  17. Dell Chromebook 13-7310 Motherboard Replacement: 手順 17、 1の画像 1
    • Release the keyboard backlight cable.
  18. Dell Chromebook 13-7310 Motherboard Replacement: 手順 18、 2の画像 1 Dell Chromebook 13-7310 Motherboard Replacement: 手順 18、 2の画像 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Dell Chromebook 13-7310 Motherboard Replacement: 手順 19、 1の画像 1
    • Release eDP cable.
  20. Dell Chromebook 13-7310 Motherboard Replacement: 手順 20、 1の画像 1
    • Release dc-in cable.
  21. Dell Chromebook 13-7310 Motherboard Replacement: 手順 21、 1の画像 1
    • Gently lift up the motherboard to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Brett Raymond
メンバー登録日: 11/01/18
469 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G1
3 メンバー
5のガイドは作成済み
コメント 1 件
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 929
