メインコンテンツにスキップ
Dell Chromebook 11-3120 Track Pad Replacement
Joseph Silveira
Joseph Silveira とその他 4 人の作成者
最終更新日: July 2, 2018
5 - 10 分
簡単
In this guide we will show you how to properly, and safely, remove and replace your laptops track pad.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell Chromebook 11-3120 Track Pad Replacement, Back Panel: 手順 1、 2の画像 1 Dell Chromebook 11-3120 Track Pad Replacement, Back Panel: 手順 1、 2の画像 2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Track Pad Replacement: 手順 2、 2の画像 1 Dell Chromebook 11-3120 Track Pad Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Track Pad Replacement, Track Pad: 手順 3、 3の画像 1 Dell Chromebook 11-3120 Track Pad Replacement, Track Pad: 手順 3、 3の画像 2 Dell Chromebook 11-3120 Track Pad Replacement, Track Pad: 手順 3、 3の画像 3
    • Using a pointed metal spudger, pull the tiny switch on top of the ribbon cable port away from the wire insertion to unlock it. Then gently remove the ribbon cable that connects the trackpad to the motherboard.
    • Use caution when removing ribbon cables as they may tear if too much force is applied.
    • Make sure the switch is lifted before pulling out the ribbon cable. Failure to do so can damage the locking mechanism.
  4. Dell Chromebook 11-3120 Track Pad Replacement: 手順 4、 2の画像 1 Dell Chromebook 11-3120 Track Pad Replacement: 手順 4、 2の画像 2
    • Using a JIS #0 screwdriver, unscrew the three 4 mm screws securing the trackpad in place.
    • Using the JIS #0 screwdriver, unscrew the two 4mm screws that hold the metal clicking mechanism in place.
  5. Dell Chromebook 11-3120 Track Pad Replacement: 手順 5、 2の画像 1 Dell Chromebook 11-3120 Track Pad Replacement: 手順 5、 2の画像 2
    • Gently lift the metal click bar off of the trackpad.
    • Lift the trackpad with the pointed metal spudger from any side to free the trackpad from its position.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Joseph Silveira
メンバー登録日: 10/19/17
401 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 11
今までの合計 1,242
