Dell Chromebook 11-3120 Back Panel Replacement
はじめに
手順 1 に進むWhen looking to repair your Dell Chromebook 11-3120, you must follow these instructions to remove the back panel of the device where the internal hardware resides. Once this is accomplished, you will have full access to the hardware inside your device. You will need a #J0 Philips screwdriver to remove the seven screws on the panel assembly.
必要な工具と部品
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
4 の人々がこのガイドを完成させました。
