メインコンテンツにスキップ
Dell Chromebook 11 CB1C13 Fan Replacement
Bryan Allen
Bryan Allen とその他 4 人の作成者
最終更新日: June 10, 2019
10分
中レベル
This guide will show you how to replace the fan. It is very common for a fan to collect dust, and without proper cooling, a device may overheat and suffer permanent internal damage. Knowing how to remove a fan for proper cleaning can be beneficial for the condition and longevity of a laptop.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 手順 1、 3の画像 1 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 手順 1、 3の画像 2 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 手順 1、 3の画像 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 手順 2、 3の画像 1 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 手順 2、 3の画像 2 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 手順 2、 3の画像 3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: 手順 3、 3の画像 1 Dell Chromebook 11 CB1C13 Fan Replacement: 手順 3、 3の画像 2 Dell Chromebook 11 CB1C13 Fan Replacement: 手順 3、 3の画像 3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
終わりに
作成者
4人の作成者と共同で作成されました。
Bryan Allen
メンバー登録日: 10/20/17
272 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017人のメンバー
UMASSD-BAILEY-F17S3G6
3 メンバー
7のガイドは作成済み
コメント 1 件
Ram?
Can i change the ram?
flip - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 26
今までの合計 1,160
