Dell AC511 Speaker Replacement
はじめに
手順 1 に進むIf you suspect one or more of the speakers in your Dell AC511 soundbar has stopped working, you may need to replace them.
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Follow the three wires connected to the speaker to find where they connect to the circuit board.
Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
