Dell AC511 Hanger Replacement
1 - 2 分
中レベル
より良い紹介部分
はじめに
手順 1 に進むIf your device does not properly hang to the bottom of compatible Dell monitors, you may need to replace one or both of its hangers.
必要な工具と部品
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
もう少しです!
終わりに
