メインコンテンツにスキップ
DJI Mavic Pro Front Vision Replacement
Kyle Kelser
Kyle Kelser とその他 4 人の作成者
最終更新日: April 1, 2019
25分
中レベル
This guide is for removing the DJI Mavic Pro Front Vision. To get to the front vision, you will need to remove the battery, upper shell, and gimbal first. In order to remove the gimbal in step 8, you will need to scrape some plastic adhesive off your device. Tweezers and three different sized screwdrivers are required for this guide.
必要な工具と部品
ツール
もっと見る
  1. DJI Mavic Pro Front Vision Replacement, Battery: 手順 1、 3の画像 1 DJI Mavic Pro Front Vision Replacement, Battery: 手順 1、 3の画像 2 DJI Mavic Pro Front Vision Replacement, Battery: 手順 1、 3の画像 3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Front Vision Replacement, Upper Shell: 手順 2、 1の画像 1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Front Vision Replacement: 手順 3、 1の画像 1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Front Vision Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Front Vision Replacement: 手順 5、 1の画像 1
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro Front Vision Replacement: 手順 6、 1の画像 1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Front Vision Replacement: 手順 7、 1の画像 1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: 手順 8、 1の画像 1
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Front Vision Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Front Vision Replacement: 手順 10、 2の画像 1 DJI Mavic Pro Front Vision Replacement: 手順 10、 2の画像 2
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Front Vision Replacement: 手順 11、 1の画像 1
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Front Vision Replacement: 手順 12、 2の画像 1 DJI Mavic Pro Front Vision Replacement: 手順 12、 2の画像 2
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Front Vision Replacement: 手順 13、 2の画像 1 DJI Mavic Pro Front Vision Replacement: 手順 13、 2の画像 2
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Front Vision Replacement: 手順 14、 1の画像 1
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Front Vision Replacement: 手順 15、 1の画像 1
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Front Vision Replacement: 手順 16、 1の画像 1
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Front Vision Replacement: 手順 17、 2の画像 1 DJI Mavic Pro Front Vision Replacement: 手順 17、 2の画像 2
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
  18. DJI Mavic Pro Front Vision Replacement, Front Vision: 手順 18、 1の画像 1
    • Remove the two 6mm JIS #0 screws by turning counterclockwise.
  19. DJI Mavic Pro Front Vision Replacement: 手順 19、 1の画像 1
    • Remove the front vision piece by pulling the piece up and away from the drone body.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kyle Kelser
メンバー登録日: 10/08/18
610 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G3
4 メンバー
14のガイドは作成済み
4ガイドコメント
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - 返信
la nacelle de mon drone mavic pro ne fais aucun mouvement quand je l'allume s'il vous plaît quel pourrait être le problème ?
Picharkayo@gmail.com
Pichar Kayo - 返信
it's most likely the ribbon cable 9-dollar fix from Amazon. that would be my first guess
J. Brown - 返信
I have error of forward motion isn’t recognizing how can I fix it please help
Aoldmilkman1 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 70
今までの合計 7,319
