メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Contixo V8 Headphone Jack Replacement
必要な工具と部品
    1. Contixo V8 Headphone Jack Replacement, Headphone Jack: 手順 1、 2の画像 1 Contixo V8 Headphone Jack Replacement, Headphone Jack: 手順 1、 2の画像 2
      • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
      • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
      • Lift the face of the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. Contixo V8 Headphone Jack Replacement: 手順 2、 1の画像 1
      • Remove the three 1.4 mm screws from the motherboard with the Phillips size #000 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Contixo V8 Headphone Jack Replacement: 手順 3、 3の画像 1 Contixo V8 Headphone Jack Replacement: 手順 3、 3の画像 2 Contixo V8 Headphone Jack Replacement: 手順 3、 3の画像 3
      • The cable marked in red is locked into place by two dark pull tabs; pull each away from the cream connection port towards the edge of the tablet. Gently remove the cable once the tabs are in the open position.
      • This cable must be reattached by inserting its end into the port with a moderate amount of force (to ensure proper connection) and then sliding both dark locking tabs back into place against the cream port.
      • The cables marked in orange are known as zero-insert force cables. To remove the connection, flip up the dark tab and gently pull the ribbon away.
      • ZIF ribbon cables must be reattached by sliding the cable into place (without force, as implied by the name) and flipping the dark locking tab back into place. Please see this guide if you're having issues reattaching the ZIF cables.
      FixBotに聞いてみる
      コメントを追加
    4. Contixo V8 Headphone Jack Replacement: 手順 4、 2の画像 1 Contixo V8 Headphone Jack Replacement: 手順 4、 2の画像 2
      • Lift the motherboard off the base and flip it over to access the headphone jack. Make sure you have the right port; check that it's shaped for headphones to be plugged in, and not the charger.
      • There will be a total of five connections between the headphone jack and the back of the motherboard; desolder all five. See this guide for information on how to desolder connections.
      • You will need to resolder the new headphone jack back to the motherboard to replace it and reassemble the device; see this guide for information on how.
      • Remove the desoldered jack. It is now ready to be replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Erin
メンバー登録日: 09/08/23
247 ポイント
2のガイドは作成済み
チーム
University of New Orleans, Team 3-2, McDonald Fall 2023 University of New Orleans, Team 3-2, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S3G2
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 31
今までの合計 504
