はじめに
The camera lens is the main mechanism which allows the camera to capture images. The lens may need to be replaced if it has scratches or is cracked. These issues could lead to blurry photos or introduce unwanted lines in the photos. This guide walks you through the steps necessary to replace the lens. When following this guide, be sure to pay close attention to the order in which you remove the components. Also, be careful when removing the lens housing. The material is very delicate and is easily damaged.
必要な工具と部品
Have the lens of the camera facing upwards.
Find the red plastic ring.
Look for two small opening above the red plastic ring.
Reference to the left of the picture and you will see the orange square.
